- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like help for setting up the CFD model (Buried in ground water pipes) because I tried many times and i receive bad results with constant temperature of the water throughout the pipe.
On inlet i set
Velocity 1500mm/s, on outlet P=0 Gage
Ground Total Temperature is 1° Celsius
Water Static Temperature 15°
Film coeff. on the outside Surfaces of the Polyethylene Pipes 5000W/m2*K (is this coefficient OK or not)
Initial Conditions
Ground Total Temperature 1° Celsius
Water Static Temperature of 15°
2 Simulations are conducted
With the first Simulation I only solve the Flow, with the Heat Transfer, Radiation and Autoconvection OFF, when the graph is converged, I continue with the second Simulation for Heat Transfer with Heat Transfer, Radiation, Gravity and Auto Convection ON and Flow is OFF.
I don't know if the result is reliable.
Thank you in advance, Dalibor Mishkov.
