BIM 360 Team Forum
Welcome to Autodesk’s BIM 360 Team Forums. Share your knowledge, ask questions, and explore popular BIM 360 Team topics.
BIM 360 Design subscription and BIM 360 Docs subscription.
6 REPLIES 6
3067 Views, 6 Replies
Hello.
I was trying the trial version of BIM 360 Design and I was reading about the difference between BIM 360 Design and BIM 360 Docs in these posts (sorry, both are in Spanish but the second has videos in English):
http://blogs.autodesk.com/latam/2018/07/30/bim-360-design-para-la-colaboracion-de-modelos-revit/
http://blogs.autodesk.com/latam/2018/09/21/autodesk-bim-360-la-plataforma-que-cambiara-la-forma-de-g...
Before reading them, I understand that BIM 360 Design is for managing information about my projects (as team members, companies, roles, etc...) and sharing Revit models in the cloud (like Collaboration for Revit); and BIM 360 Docs is the Document Management module for BIM 360 platform (that includes Glue, Build and Ops), where I can make annotations in 3D model views or 2D sheets as Markups and Issues and navigate through them.
My question is if getting a BIM 360 Design license I can use Document Management module to view 3D models from Revit (for example) or I need to get a BIM 360 Docs license to be able to view those models or to use markups and issues. Is it necessary get both licenses or BIM 360 Design includes BIM 360 Docs?
Greetings,
Álvaro.
6 REPLIES 6
Luciane_Conceicao
Hi Alvaro,
Thank you for your question.
A BIM 360 Design license entitles you to use BIM 360 Docs.
BIM 360 Design needs BIM 360 Docs to work (that is where the files are stored in the cloud), so you will have Docs in any case.
I hope this clarifies your question.
Cheers,
Luciane
Luciane Conceição Taylor
Product Support Specialist
Autodesk, Inc.
Please click the button "Accept Solution" if this suggestion resolves your issue.
Luciane_Conceicao
Hi Alvaro,
Please let me know if you need further assistance with this query.
Cheers,
Luciane
Luciane_Conceicao
Hi Alvaro,
Please let us know if you need further assistance with this query.
I am accepting it as solution but if this is not the case please update this post.
Cheers,
Luciane
I have BIM 360 Design licenses; I would like to know how to use BIM 360 Docs. In other words, how wold I access it?
Aarti
Hi Aarti,
Please check this part of the help file:
Get Started with BIM 360 Design
Cheers,
Luciane
Hi
I have an additional question about the licensing policy. We are working on a project with 5 internal employees and 13 external partners. This via bim 360 design. We have started a bim 360 docs environment. Do we also need to provide the docs licenses of our external partners? De BIM 360 design licenses are provided by everybody themselves , but as far as I know the docs licenses do not fall under the BYOS policy...
Thanks a lot!
