BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
REVIT VERSION CONFLICT
5 REPLIES 5
elicr
319 Views, 5 Replies
i have a problem trying to collaboration a REVIT 2021 FILE INTO A PROJECT THAT EXISTS
The project has REVIT files that are UPLOADED WITHOUT collaboration tools from REVIT in 2023 version- however, I can't access this project folder when tryin gto collaborate to it from REVTI now~!!.
This was possible in the past- has this changed?
#revitversion
#oldrevit
5 REPLIES 5
Yien_Chao
in reply to: elicr
hi
do you mean you would like to open a non collaborative cloud file from another version of your Doc project's version?
elicr
in reply to: elicr
In the past i have uploaded different versions of revti file tot a project in the B360 folder and all was OK
but for some reason i can't collaborate the particular version (2021) to a project.
My suspicion is that at some point a different version was collaborated and now the project is 'stucks' in the later version. I now in a situation where i can't identify which version the project is at now (maybe by trying to access it from dfirrenect versions)
but- more important, I want to updo this version upgrade to the project also
Yien_Chao
in reply to: elicr
i dont know in the past few years, but since at least 2022, the project could have only one version of file. ie : if you started a project on ACC in Revit 2022, only that version will be allowed to be in worksharing.
elicr
in reply to: elicr
i would imagine that after i remove the advanced model - the project may reset to "neutral":  ?
Yien_Chao
in reply to: elicr
I think i will "stuck" with the initial file version.
