BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
ACC Photomanager
6 REPLIES 6
Maximilian_Mäkel
11348 Views, 6 Replies
ACC Photomanager
how do I tag multiple pictures at the same time, or do I have to do it for each one individually. Also is it possible to preset tags and locations when using the mobile device?
Secondly when viewing a picture, the zoom function don´t work well. Zooming in using the mousewheel currently also displaces the picture.
Lastly it would be great if you could use the GPS-data of the uploaded pictures to project them on an individal sheet and not just on a basic google maps overview.
Best Regards,
Max
6 REPLIES 6
Hi @Maximilian_Mäkel,
Are you trying to tag multiple photos in the app or in the web browser? I am not sure you can tag multiple photos in the app but you can easily do it through the web browser.
I have the same issue with my mouse so I just use the + and - on the screen to zoom.
Why not put your idea forward in the Idea forum.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Hi @gareth.spencer1,
thank you for the quick answer. However that is not what I´m looking for. I can mark multiple photos, but then I can´t set a tag or location for all of the marked photos.
Best Regards,
Max
Are you taking about the location or GPS?
If you are trying to add the location/position on-site you need to set the location through Project Admin > Settings > Locations.
Otherwise the GPS location is set from the image when it is taken with the GSP location turned on.
You will need to select the image and then once opened add the relevant tags.
Gareth Spencer
I know but the main problem is that you have to set it individually for each photo and you can't make multiple selections. For example 10 photos with location xy, then you have to set it individually for each of the 10 photos. It would be easier if you could do it directly with a multiple selection.
I totally understand. Why not put it forward as an idea in the BIM 360 Ideas Forum as a suggested update.
Gareth Spencer
I already published it as an idea. Hopefully they add the function soon.
https://forums.autodesk.com/t5/bim-360-ideas/photomanager/idi-p/11809429
Technology Administrators
