BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Restore Backup - Synchronize vs Publish
2 REPLIES 2
ASilvas.com
694 Views, 2 Replies
Can a synchronization be restored if not published? For example multiple synchronizations later the user realizes that the 3rd of 6 synchronizations needs to be restored. Since only at the 6th synchronization the file was published, does this mean the synchronization 3 of six is not retrievable?
Labels (1)
2 REPLIES 2
jens.krause
in reply to: ASilvas.com
Hi @ASilvas.com ,
this can be done via the "Manage Cloud Models" dialog in Revit:
  1. Consider creating a backup of the currently synced version by saving the file locally with "Save as".
  2. In Revit, open a cloud model and go to "Collaborate" - "Manage Cloud Models"
  3. Pick your project, then search for the cloud model you want to restore
  4. Move your mouse over the line of the corresponding models, select "Actions" - "View Versions"
  5. (Think twice! Then...) Use the "Restore" button on the version that you want to restore. 2020-09-29 10_23_10.jpg
I hope this helps.
Kind regards,
Jens Krause
Autodesk Support Team
ASilvas.com
in reply to: jens.krause
Very helpful, thank you.
