Can a synchronization be restored if not published? For example multiple synchronizations later the user realizes that the 3rd of 6 synchronizations needs to be restored. Since only at the 6th synchronization the file was published, does this mean the synchronization 3 of six is not retrievable?
Solved by jens.krause. Go to Solution.
Hi @ASilvas.com ,
this can be done via the "Manage Cloud Models" dialog in Revit:
I hope this helps.
Kind regards,
