BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Report Schedule Saving pushing next run out....
1 REPLY 1
brucegund
268 Views, 1 Reply
Well this is annoying. In Reports if I go in and modify a saved Report that is scheduled to run in two weeks, each time I go in and modify it pushes the next run another two weeks. I did noticed this till after make the 3rd modification. The next run should be October 7th. It is now showing sometime in December. Not cool. This is a report that the whole team is using to review Site Observations and photos. Please fix.
Labels (1)
1 REPLY 1
jens.krause
in reply to: brucegund
Hi @brucegund .
This sounds as if the Scheduling function does not work as intended. As this might require a code change from the development team, I would recommend you to create a support case with Autodesk Technical Support for this issue. The support team might need some account-specific information from you to follow up with the development team. It is very much easier to handle and track this in a support case than in a public forum thread. I hope you understand. Please let me know if you have remaining questions or concerns.
Kind regards,
Jens Krause
Autodesk Support Team
