How can I remove these accounts form my docs
Solved by bogdan_ciobanu. Go to Solution.
Hi @Anonymous,
Thank you for your post. My name is Bogdan and I am with Autodesk Technical Support.
Those accounts you are seeing are accounts to which you have been invited by other users? If that's the case, you should ask those users to have you removed from their projects and you will not see those accounts again.
If those are your accounts, you should know that we won't be able to delete them. Please see an Autodesk Knowledge Network article on this subject, here.
Hope this helps.
If my post answered your question, thank you for accepting it as a solution so that other users can find it easily and benefit from it if they have the same question.
Thank you!
Best regards,
Bogdan
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @bogdan_ciobanu provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
