BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Procesed IFC file does not show all elements it contains
15 REPLIES 15
Message 1 of 16
nic.maes
1367 Views, 15 Replies
We have an uploaded IFC file wich does not display all elements it contains (mainly rebar elements)
Native application is Tekla Structures 2016i. IFC Schema is 2X3.
When downloading and opening the file in Solibri, all elements are present.
Also opening the IFC file in Revit 2018.3 shows all elements.
Are there some settings we can provide to our sub to get better results in the BIM360 viewer?
Best regards
Nic Maes
Tags (1)
15 REPLIES 15
Message 2 of 16
anil_mistry
in reply to: nic.maes
Hi @nic.maes,
Thank you for participating in our Community! Would you be able to share screen capture and if its possible to share IFC with me so I can do further investigation.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 16
nic.maes
in reply to: anil_mistry
Please see attached sreencapture
Revit is 2018.3 - IFC importer is 18.4.0.0
I can send you the IFC file
Best regards,
Nic Maes
Message 4 of 16
anil_mistry
Hi @nic.maes,
Thank you for your reply. Would you be able to send me this file via PM? Please let me know if you have trouble sending via PM then I will send you A360 project drive invite.
Anil Mistry
Message 5 of 16
anil_mistry
Hi @nic.maes,
I just send you A360 project invite. Please upload requested file and let me know once you are done uploading.
Anil Mistry
Message 6 of 16
nic.maes
Hi @anil_mistry
just uploaded the file.
Best regards
Nic Maes
Message 7 of 16
anil_mistry
Hi @nic.maes,
Thank you for sharing requested information. I will download shared file and will try to duplicate this behavior on my end and will give you an update soon.
Anil Mistry
Message 8 of 16
anil_mistry
Hi @nic.maes,
I am sorry for late reply. I just want to let you now that I wasn't able to duplicate this behavior on my end (please see attached). I would suggest to clear your Google Chrome browser history and try again. Let me know if this helps.
Anil Mistry
Message 9 of 16
nic.maes
@anil_mistry
Can you please confirm that rebar is present in the walls in the Revit file and not in BIM360? As that is what i'm seeing.
The IFC File i send you on the A360 file has the same problem.
I don't see what Chrome's history has to do with how BIM360 parses IFC files.
Best regards
Nic Maes
Message 10 of 16
anil_mistry
Hi @nic.maes,
I do see rebar in Revit and Docs.
Anil Mistry
Message 11 of 16
nic.maes
@anil_mistry
Sorry to keep you bothering with this, but I do not see the rebar inside the precast walls.
Can you send me a bim360 link to your test? or a picture of the rebar mesh sheets in the wall?
For us this is important because subcontracters upload there files to bim360 and we want to look at the content without downloading the files and opening them in other software.
Best regards
Nic Maes
Message 12 of 16
anil_mistry
Hi @nic.maes,
I just want to let you know that I have send you an email with some screen capture. Let me know if this helps.
Anil Mistry
Message 13 of 16
nic.maes
@anil_mistry
Thanks, but in non of the BIM360 sreencaps i see the rebar inside the wall.
Attached is a Revit screencapture with a wall hidden.
We don't get this rebar in BIM360 Docs
Best regards,
Nic Maes
Message 14 of 16
anil_mistry
Hi @nic.maes,
I just want to let you know that I have escalated this behavior to development team for further investigation and I will give you an update as soon as possible.
Anil Mistry
Message 15 of 16
nic.maes
@anil_mistry
Any update  on this?
Best regards
Nic Maes
Message 16 of 16
nic.maes
@anil_mistry
any progress in the investigation?
best regards,
Nic
