BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
OCR linking between subfolders
7 REPLIES 7
Message 1 of 8
465 Views, 7 Replies
Is it possible to create a sub-folder for architectural, structural, mechanical, etc. and still have the architectural drawings be linked to the structural?
7 REPLIES 7
Message 2 of 8
mespaillat
Hello @Anonymous,
I do not believe the workflow you are describing is supported in Docs at this time. There is a specific workflow in place for uploading linked files which does not allow the user to specify multiple/alternate destinations for files that are linked to a parent (host) file. This would be a great suggestion for you to post to our BIM 360 Ideas as a desired feature/capability.
The recommended workflow to upload linked files to Docs can be found here.
Please advise if this response was helpful. If so, please click Accept as Solution.
Thank you for choosing Autodesk.
mespaillat.
Thank you for choosing Autodesk Support!
mespaillat
Autodesk Support Team
Message 3 of 8
anil_mistry
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @mespaillat provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 8
in reply to: anil_mistry
Not completely, it is still hard to properly organize files without the use of sub-folders. Thank you for your response tho.
Message 5 of 8
Tags (1)
Message 6 of 8
mespaillat
Hello @Anonymous,
Are you saying that you are unable to create sub folders in Docs, or where you referring to the workflow you described?
"Is it possible to create a sub-folder for architectural, structural, mechanical, etc. and still have the architectural drawings be linked to the structural?"
There should be no issue with creating sub folders in Docs, please advise if you are and we will gladly assist.
mespaillat.
mespaillat
Message 7 of 8
in reply to: mespaillat
I have no issue creating a sub-folder within the plans tab. However, once sheets are placed into their respective sub-folders they no longer link to other sheets found in separate sub-folders within the plans tab.
Message 8 of 8
It would be nice if we could run a hyperlinking function after we have our folder structures set up and allow the OCR / Hyperlinking function to look at multiple subfolders at the same time. Even into the Project Files section to hyperlink all our our drawings together regardless of subfolder. In addition it would also be nice if the OCR capability also looked at markups as well. If the markup says RFI-01 go ahead and hyperlink to that document. These types of features really enhance the usability of docs.
The problem is that we are limited by having to upload all of the documents in a single folder in order to get them to hyperlink together. Many time project teams use folders to separate disciplines and sometimes drawings reference other drawings that exist within different disciplines/folders. Using docs it does not automate the linking between different disciplines if they exist in different folders.
Technology Administrators
