BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
DWFX properties on BIM360 gives wrong dimensions compered to the original file and measurements
2 REPLIES 2
Gal_Limor
183 Views, 2 Replies
Hey all,
I'm using Revit to model and export DWFX with a few layers of a wall.
on Revit and on Design Review the length parameter shows 3' 2" -3/16", when reviewing the same DWFX on BIM360 Properties it shows 3'.
other parameters (as height) shown as in Revit with its accurate dimensions (8'3"- 5/16").
what could be the cause of this? is there any export option to show the correct dimensions?
2 REPLIES 2
a_meteni
in reply to: Gal_Limor
Hi, Have you tried to alter the Settings configuration of Display units / Precision?
Gal_Limor
in reply to: a_meteni
thank you for your replay @a_meteni
precision is set correctly, other measures taken in that view shows full and accurate dimensions.
