hi
I have a problem that I have a revit file with links in docs 360 , and when I downloading it from docs, the file is not downloading the links that are in the file
dose any one else encounter this issue?
hi Joe ,
i have the latest version of desktop connector, all the links files was published from revit.
I want to know why when I choose Direct Download from Document Management, it does not download all the files that are linked to the main file?
Oh I see, I misunderstood. However I would expect that to be the case, if downloading from Docs. If you open the file in Revit though, the links are still attached?
