BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
downloading revit file with links directly from docs
5 REPLIES 5
tzahia
329 Views, 5 Replies
hi
I have a problem that I have a revit file with links in docs 360 , and when I downloading it from docs, the file is not downloading the links that are in the file
dose any one else encounter this issue?
5 REPLIES 5
joe_keogh
in reply to: tzahia
Hi @tzahia
Do you have the latest version of Autodesk Desktop Connector?
Are all the Linked models saved into BIM 360 Docs?
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
tzahia
in reply to: joe_keogh
hi Joe ,
i have the latest version of desktop connector, all the links files was published from revit.
I want to know why when I choose Direct Download from Document Management, it does not download all the files that are linked to the main file?
joe_keogh
in reply to: tzahia
Oh I see, I misunderstood. However I would expect that to be the case, if downloading from Docs.  If you open the file in Revit though, the links are still attached?
Joe Keogh
tzahia
yes.
Is the ability to download the file with linked files directly  exist?
joe_keogh
in reply to: tzahia
You can with BIM 360 Glue, have a look Here
Joe Keogh
