I was trying the new update Autodesk made to upload .pdf to the RFIs, Thank you Autodesk, we needed that.
While I was uploading directly from my computer I accidentally uploaded the wrong .pdf.
How can I erase the .pdf Attachment while the RFI is open?
Solved by roeioved. Go to Solution.
@Anonymous We soon plan to expand RFIs managers permissions to control and mange the RFIs attachments - including deletion.
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did @roeioved reply answer your question?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
