Is it possible to define portrait title block?
Title block information is located horizontally at the bottom of the sheet. Not vertically align.
Solved by scott.a.green. Go to Solution.
@Anonymous
It shouldn't matter if the document is a landscape or a portrait - you can define the title-block area using the crop tool and then save the new title-block layout as a new template to use with other documents using the portrait orientation.
For reference:
To Manage Layout Templates (Title Blocks)
If this answers your question, please mark as "Accept as solution". If you still require some assistance with this, please reply and I'd be happy to help you further.
-Scott
Thank you for your posting @Anonymous. Did @scott.a.green's post answer your question? Please feel free to let us know if you have more questions.
Cheers,
Yuri
