BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Copying Folders on BIM360 Docs
16 REPLIES 16
Message 1 of 17
6955 Views, 16 Replies
How to copy a folder (containing files and subfolder) from one folder to another folder on BIM360 Docs.
16 REPLIES 16
Message 2 of 17
mespaillat
Hello @Anonymous,
Thank you for posting to our forums.
With regards to copying folders (and contained items) within BIM 360 Docs, this is not an available action at this time. To see the full list of folder related actions in BIM 360 Docs, please see the "To Work with Folders" in the Docs product help documentation.
The good news is this functionality is on the road map for Docs, but no date or timeline has been set. I recommend you visit the BIM 360 Ideas board, and VOTE UP - SM.png the following posts to ensure you contribute to the demand for implementation of this feature:
If you find this response was helpful in answering your inquiry, please click the ACCEPT AS SOLUTION button.
Thank you for choosing Autodesk.
mespaillat
Autodesk Support Team
Thank you for choosing Autodesk Support!
mespaillat
Message 3 of 17
anil_mistry
in reply to: mespaillat
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @mespaillat provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 17
Thank you so much for the prompt reply.
Message 5 of 17
Another Major issue with a very basic functionality.
Each year we start a knew sub-folder structure, same as the previous year.
Looks like we are up to make it all manualy. I thought IT was about NOT doing things manualy...
Message 6 of 17
Four years later and this very basic feature is STILL unavailable. We're trying out Docs on a new project and the lack of this functionality alone is a deal breaker.
Tags (1)
Message 7 of 17
alvaro.bellonXKNWK
Agreed! Obviously, every practice has a specific folder structure and support files that are used across all of their projects. Still, all of these subfolders and files need to be created/placed manually, one by one, to each project_!
A basic copy/paste functionality would save heaps of time here, wasted in performing a boring and repetitive task...
Message 8 of 17
matthew.ngo
Just keeping this thread alive until Autodesk adds Copy for folder management. They want companies to use BIM360 as the "ultimate" coordinating platform but force people to create folders 1-by-1 for every project, submittal, project team, etc.
Please fix.
Message 9 of 17
gabeLXVRB
This thread and all associated threads on same topic are absolutely absurd.  Four years for a copy option for single and multiple folders is unnecessary.  Who is getting removed from Autodesk and who is being onboarded to address this issue?
Message 10 of 17
jsanders
Hello, when will this be implemented ? This is extremely urgent demands from our clients.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Message 11 of 17
RobDraw
in reply to: jsanders
Apparently, it's not as easy as people think it is. The IDEAS forum is where you should be discussing this.
Rob
Message 12 of 17
peter.kennedyGJ87D
I cant believe this is still not an available function, very basic function to enable!
Message 13 of 17
Why don't you go over to the IDEAS forum and do something about it. Complaining isn't very productive.
Rob
Message 14 of 17
I've found the solution to this problem. Download Autodesk Desktop Connector and copy paste from there 👍
Message 15 of 17
ashraful_islamBKFWZ
BIM360 till not have any option to copy a folder. And resulting huge time consumption to create same nature folders
Need help
Message 16 of 17
Hello @ashraful_islamBKFWZ you can use Autodesk Desktop Connector to copy paste folders with other subfolders. It's very handy little app that I highly recommend.
Message 17 of 17
ocarjohann
2024 and this keeps being a pain in the gutter.... I know Desktop Connector Exists, yet many times the operation of uploading folders must be done from different computers that may not have the option to install third party apps, this thread started back in 2018, so 6 years later I ask; is this going to be implemented at all???
