The weather data in the daily logs are not accurate.
In my project I got this:
It is reporting a high value during the night and 16 degrees should be 25 degrees.
By the way: the weather information on Project Home page is good
Hey Johan,
Thank you very much for your input.
We are looking into it.
Can you please share where are you located?
We are checking if time differences between you and the project might cause the issue.
David
Hi @johan.cantryn,
I am going to follow-up with @david_kadyshewich and will give you an update soon.
Thank you and have a great day!
Thanks for the information Johan,
We are looking into the problem.
Will use this channel to update once we have a clearer understanding of what caused the issue.
Regards
David
Hi @johan.cantryn,
I just want to let you know that development team is investigating this behavior and @david_kadyshewich will give you an update as soon as he has more information.
I am experiencing a simular issue. The weather data for Santiago (Chile) is giving wrong temparature. I shows super high temperatures.
It happened the same when I tried other locations in the central part of Chile.
I compared the data with a weather file from DOE using climate consultant. So you can see the differences.
Please find attached the PDF result file.
Regards
Hi @Anonymous,
Thank you for participating in our community and your feedback! As I mention in my previous post saying that development team is investigating this behavior and @david_kadyshewich will give you an update as soon as he has more information. Let me know if this helps.
