BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
BIM 360 Field Management - Daily logs weather data not correct
7 REPLIES 7
Message 1 of 8
johan.cantryn
744 Views, 7 Replies
johan.cantryn
The weather data in the daily logs are not accurate.
In my project I got this:
It is reporting a high value during the night and 16 degrees should be 25 degrees.
By the way: the weather information on Project Home page is good
7 REPLIES 7
Message 2 of 8
david_kadyshewich
Hey Johan,
Thank you very much for your input.
We are looking into it.
Can you please share where are you located?
We are checking if time differences between you and the project might cause the issue.
David
David Kadyshewich
Senior Product Manager
Hey Johan,
David
David Kadyshewich
Message 3 of 8
johan.cantryn
Hi David,
I'm based in Belgium.
Johan
Hi David,
Johan
Message 4 of 8
anil_mistry
in reply to: johan.cantryn
anil_mistry
Autodesk Support
Autodesk Support
Hi @johan.cantryn,
I am going to follow-up with @david_kadyshewich and will give you an update soon.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Hi @johan.cantryn,
Anil Mistry
Message 5 of 8
david_kadyshewich
Thanks for the information Johan,
We are looking into the problem.
Will use this channel to update once we have a clearer understanding of what caused the issue.
Regards
David
David Kadyshewich
Regards
David
David Kadyshewich
Message 6 of 8
anil_mistry
Autodesk Support
Autodesk Support
Hi @johan.cantryn,
I just want to let you know that development team is investigating this behavior and @david_kadyshewich will give you an update as soon as he has more information.
Anil Mistry
Hi @johan.cantryn,
Anil Mistry
Message 7 of 8
in reply to: david_kadyshewich
I am experiencing a simular issue. The weather data for Santiago (Chile) is giving wrong temparature. I shows super high temperatures.
It happened the same when I tried other locations in the central part of Chile.Wrong climate data.JPG
I compared the data with a weather file from DOE using climate consultant. So you can see the differences.
Please find attached the PDF result file.
Regards
Regards
Message 8 of 8
anil_mistry
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our community and your feedback! As I mention in my previous post saying that development team is investigating this behavior and @david_kadyshewich will give you an update as soon as he has more information. Let me know if this helps.
Anil Mistry
Hi @Anonymous,
Anil Mistry
