BIM 360 Field - Checklists - Add item - response type: Signature
zawmyotun
zawmyotun
Other than, Yes/No, True/False .. etc,
Just wondering if we could allow sketch field.
1. So we could leave sign 1, sign 2, sign 3,
Below is as an example of our current practice.
we may argue that account is already considered digital sign, we all do have other concern to have digitally let them sign. Below is 1 years ago request by @jlannen
https://forums.autodesk.com/t5/bim-360-ideas/bim-360-field-checklists-add-item-response-type-signatu...
just trying to re active at this forum since i don't find above post among 25 post in this new generation category.
Shirin.arnold
Hi @zawmyotun,
This is something we are taking into consideration for Field Management. Signatures as a response type along with the ability to sign checklists as we can in BIM 360 Field today.
Thank you for your request.
Kind regards,
Shirin Arnold
Sr Product Line Manager
anil_mistry
Autodesk Support
Autodesk Support
Hi @zawmyotun,
I'm just checking in to see if you need more help with this. Did the suggestion that @Shirin.arnold provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
