Using Bim360 with student version of Revit
yu85.info
yu85.info
Hi, If I have purchased  a regular license of BIM 360 and I have a student license of Revit, is it possible to use them together?
Thank you very much
pendean
Community Legend
Community Legend
May I ask why does a student need a single user license of BIM360?
What are your expectations or hopes of use?
yu85.info
Participate in a collaborate project. I need to do the electricity part in
MEP.
Is it possible?
pendean
Community Legend
Community Legend
If I may ask another question: are you trying to use your EDU license in a commercial environment?
Or is this a school project and you are collaborating with other students who also purchased single user licenses of BIM360?
yu85.info
That is correct I am trying to collaborating with other students who also
nolangene
You should already know the answer actually. If you have purchased a BIM Collaborate Pro license then one of your group should have set up their hub. Or all of you could. But the Project you are collaborating needs to be put up on just one of your BIM 360 hubs. Then you setup the project and invite the others to the project. That is completely separate from Revit or Revit student version. Then you open up your Revit student version and see if you can navigate to the project on one of your hubs. So have you setup a hub (every license of BIM Collaborate Pro can set one up)? If yes did you login to BIM360 to that hub? Did you setup a project and invite the others. Anohter way to tell if student should work (FYI I have never used a student version so do not know) if you are in 2021 or less you should see a BIM 360 section on the Home page, in Revit 2022 and up you will see an Autodesk Docs section on the Home page. Let me know curious. Hope this helps.
