Autodesk Construction Cloud - cost plus contract
erinznire
erinznire
Good day Humans!
I am trying to figure out how you set up a cost plus contract budget etc. in Autodesk Construction Cloud. I would expect this was a commonly required element..? But since there are no ootb settings for markup (aside from change orders) and a contract type field that does nothing and absolutely nothing to find online I feel like either it just can’t be done or I’m way over thinking it and it’s super simple…
hopefully it’s the former. Any help is greatly appreciated!
thank you!
Jason_Kai_Jiang
Hi @erinznire
Assuming you would like to calculate markup budgets from non-markup budgets, could you please confirm whether the following scenarios may happen in your daily work of cost-plus contracts?
Budget 1: Labor       100
Budget 2: Material  200
Budget 3: Markup (10%)
1. Markup budgets are calculated from the sum of non-markup budgets.
For example, Budget 3 = (100+200)*10% = 30
2. Markup budgets are calculated from the selected non-markup budgets.
For example, Budget 3 = Budget 1: Labor * 10% = 100*10%=10
3. Markup budgets are fixed amounts.
For example, Budget 3 = 50
4. After the calculation, do we need to forbid other operations to markup budgets? For example, internal budget transfer or transfer change order from/to markup budgets.
5. After the markup budgets are calculated, would you like to spread those budgets to non-markup budgets related Main Contract SOVs?
For example, for the above budgets, the main contract SOVs are as follows:
Main Contract 01
    Labor: 110 (=100+100*10%)
    Material: 220 (=200+200*10%)
Thanks and best regards
Jason Jiang
Senior Product Manager
ErinChristoffersen
Observer
Observer
Thanks Jason,
We don’t quite have a budget yet and we’re billing out for pre-construction items. So we needed to add markup on a cost item to bill to the client..we’ve resorted to just changing the quantity to 1.134 to “add” a markup.
thank you for taking the time to reply!
