Revit links are not visible in 3D
Bnilath
Message 1 of 9
Bnilath
We tried to publish one 3D view directly from Revit, but the linked models are not visible in the view. Please advise.
Bujair
Replies (8)
Message 2 of 9
leslie.han
Hi Bujair,
Could you please share the parent model and its linked files with me by a private message? I will notify the development team to check for you asap.
Thanks and best regards,
Leslie Han
Autodesk BIM 360 Docs team
Message 3 of 9
leslie.han
Hi Bujair,
I have received your files, our team will try to reproduce the issue asap. I will keep you posted for any result. Thanks.
BR/Leslie
Message 4 of 9
Bnilath
Hi Leslie,
Can you please update the status.
Bujair
Message 5 of 9
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
Thank you for your patience. I will follow-up with @leslie.han on this behavior and one us will give you an update soon.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 6 of 9
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
Would you be able to let me know how did you upload this linked files? Did you uploded via BIM 360 Docs or C4R(Collaboration for Revit)?
Thank you and I look forward to your reply.
Anil Mistry
Message 7 of 9
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I’m just following up to see if you were able to gather the information I had previously requested on (date) to assist me in troubleshoot your issue.
Anil Mistry
Message 8 of 9
Bnilath
Hi Anil,
We uploaded via BIM 360 (Used the second option in Upload ).
Bujair
Message 9 of 9
leslie.han
Hi @Bnilath,
Thanks for your reply. Here is the workaround for your issue, please have a try:
  1. Upgrade all your models to Revit 2018 and save.
  2. Upload your models via BIM 360 Docs again and check the result.
Hope this could help. And please keep me updated with your latest result and let me know if you need more help.
Leslie Han/BIM360 Docs Team
