Recovering deleted files with complete version history
Bnilath
Message 1 of 11
Bnilath
By mistake, someone deleted one drawing from BIM 360. Can you suggest a way to recover the drawing with complete version history?.
I can recover single file. But I need the file with complete version history.
Replies (10)
Message 2 of 11
zijing.zhang
Hi @Bnilath,
Thanks for your posting.
You could select the folder which you deleted the file by mistake, then click Deleted items icon, and selected the deleted file, click Restore btn:
Here is the version history before deleted a document in Plans or its subfolders:
before deleted in Plansbefore deleted in Plans
Here is the result if you restore a document for Plans or its subfolders:
after restored in Plansafter restored in Plans
Here is the version history before deleted a file in Project files folder or its subfolders:
before deleted a file in Project files folderbefore deleted a file in Project files folder
Here is the result if you restore a file for Project files folder or its subfolders:
As you see above, you will get the complete version history after restored a deleted file by mistake.
Zijing
Message 3 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I'm just checking in to see if you need more help with this. Did the suggestion that @zijing.zhang provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
Message 5 of 11
And if I don't see in deleted items??
I deleted it yesterday and today I dont see anything in deleted items....
@zijing.zhang wrote:
Hi @Bnilath,
Zijing
Message 6 of 11
Hi @Bnilath,
Zijing
Message 7 of 11
amit.mSESPG
I can't recover the file...
Hi @Bnilath,
Zijing
Hi @Bnilath,
Zijing
Message 8 of 11
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our community! Since this requires further investigation I would suggest logging support request and someone from our support team will help you resolve this issue.
Anil Mistry
Message 9 of 11
ptranbergNTI
@anil_mistry  Is there a time limit for restoring files or are deleted files available forever?
Regards
Peter Tranberg
NTI A/S, Denmark
revitogbim.blogspot.com
Message 10 of 11
sureshkumar89N4Q
cant we get  only one file, as we are getting 2 files as uploaded and reloaded.
Message 11 of 11
sureshkumar89N4Q
When I restore the file it is same versions of two files. 1.restored and another us 2.uploaded.Can't we get only one.
