PDF upload issue
PDF upload issue
Bnilath
Message 1 of 17
PDF upload issue
Bnilath
I can’t able to upload pdf files to one specific folder. I am getting frequent error message. Please advise.
Thanks & Regards,
Bujair
Replies (16)
Message 2 of 17
We have tried the same files in another folder and it works, there is some kind of an issue with this specific folder/files not accepting these files.
Message 3 of 17
zijing.zhang
Hi @Bnilath and @Anonymous,
We will check it.
Could please provide your failed files to us, it will help us to debugging and narrow down the problem you're experiencing.
Feel free to send me a private message or email me with your files.
Thanks very much in advance,
Zijing
Message 4 of 17
Bnilath
Hi Zijing,
Files shared through private message. Please check and advise.
Thanks & Regards,
Bujair
Message 5 of 17
zijing.zhang
Hi @Bnilath
Thanks for your promptly reply, it is on the radar of the development team. An update will be posted on here once the issue is resolved.
Zijing
Message 6 of 17
ilai_rotbaein
Can you please check in your publish log if there's a previous upload of these files that is still processing? That could be one reason why you can't upload to that specific folder.
Ilai
Message 7 of 17
zijing.zhang
Hi @Bnilath,
I just tried myself, and I couldn't reproduce this issue.
I uploaded these 4 pdf files in a subfolder of Plans, and here is the result:
in publish login publish log
As @ilai_rotbaein mentioned, if you uploaded the same file when the pervious version was still in processing, the second one would be failed.
If not, could you please provide more details like steps to help us to reproduce or add me into the folder which maintained errors?
Thanks in advance,
Zijing
Message 8 of 17
When we replicate this issue in a test environment in our "training" project it works fine, we don't seem to have an existing spooling with the same files. Probably there is an earlier version already uploaded and the expected behaviour would be to version up rather than refuse to upload.This sub-folder is part of the project hierarchy and these files need to go exactly into this location.
Message 9 of 17
zijing.zhang
Hi @Anonymous and @Bnilath,
Thanks for your reply. Please have a try to re-upload those PDF files and avoid that the pervious version is still uploading/processing before published in the same folder. If you could still reproduce this issue, please contact me.
Zijing
Message 10 of 17
Jason_Kai_Jiang
Hi asafaryan,
If the same file is still under Review step, the new upload can't generate a new version and will cause the kind of failure. Another "create" fail may cause by file lock.
Could you please hove the mouse to the red "!" markup and share us the error message?
Thanks and best regards,
Jason Jiang
Autodesk BIM 360 Document Management team
Jason Jiang
Senior Product Manager
Message 11 of 17
Bnilath
Hi Jason,
Please find the attached file. I deleted all previous versions and tried, but still showing the same error message.
Thanks & Regards,
Bujair
Message 12 of 17
Jason_Kai_Jiang
Hi Bnilath,
I will notify the engineering team to investigate it asap.
Jason Jiang
Jason Jiang
Message 13 of 17
Jason_Kai_Jiang
Hi Bnilath,
The failure was not caused by the previous versions that have already finished the extraction and displayed on document list.
It was caused by the job has not finished the extraction and may be in the Review step. Could you please double check the Publish Log GUI? Are there any stuck job or job in Review state? If yes, please cancel them before uploading the same file.
Jason Jiang
Jason Jiang
Message 14 of 17
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I'm just checking in to see if you need more help with this. Did the suggestion that @Jason_Kai_Jiang provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 15 of 17
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
Message 16 of 17
Bnilath
Hi Jason,
Thank you for your replay.
It is working now.
Bujair.PN
Message 17 of 17
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
Thank you for your reply and I am glad to hear that the issue is now resolved. Please, let us know if you have any other questions or concern.
Anil Mistry
