capturing wrong titleblok info
Message 1 of 11
The purpose is defeated when this happens, and it happens very often:
Replies (10)
Message 2 of 11
another similar issue with recognition that kind of forces us to spend tremendous time on publish/review and be extremely attentive is misinterpreting letters for numbers and vice versa, example below:
Message 3 of 11
this could have been avoided by some machine learning excercise, not sure, just thinking out loud
Message 4 of 11
more misinterpretation examples:
Message 5 of 11
ilai_rotbaein
Hi there,
Thank you for the detailed feedback and exampled, very useful. I can share with you that this is already an area of focus for us and we're working on a number of improvements to the accuracy of the title block OCR. In parallel, we're also working on constant improvement to the entire extraction process, we've released a number of improvements lately that significantly reduce the extraction time and we will have a few more coming shortly.
I invite you to continue sharing your feedback with us, it is helping us tremendously and leads to continuous improvement of the BIM 360 experience.
Ilai
Message 6 of 11
zijing.zhang
Hi @Anonymous,
Thanks for your feedback. I logged a ticket regarding to your feedback, it is on the radar of the development team. An update will be posted here once the issue is resolved.
Zijing
Message 7 of 11
zijing.zhang
Hi @Anonymous,
Could you please provide your pdf files to us (send me a PM or email me), it might help us narrow down the problem you're experiencing and help us to debug as well.
Thanks a lot in advance,
Zijing
Message 8 of 11
zijing.zhang
Hi @Anonymous,
May I ask what's your default language of the browser when you were adding the title blocks?
From the first picure, it seems the text is not recognised as English.
In addition, could you send me a private message or email me your pdf? It will help us to do further investigation about this.
Thanks in advance,
Zijing
Message 9 of 11
Client of ours is having a similar issue, it looks to be related to the change in font size.
Any help would be appreciated.
Message 10 of 11
zijing.zhang
Hi @Anonymous,
1.Could you please describe how did you add the title and number in defining title block step, like describing the blue rectangle box covered area when you define the title in the title block image? a screenshot would be really appreciated.
2.Could you send me a private message with your file? So that we could continue the investigation for your issue.
Zijing
Message 11 of 11
zijing.zhang
Thanks very much for your promptly reply, @Anonymous , I got you message. We will check and continue investigating for your issue.
Zijing
