Message "Couldn't upload file..."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I don't understand why the system gives me the message: "Couldn't upload file because it was previously saved to this folder using Revit Cloud Worksharing. Please try uploading to a different folder, or use Revit Cloud Worksharing to save to current folder."
The original Revit file was created by architect using Revit Cloud Worksharing, and then published.
I found the file with the web based BIM360 Docs system and copied it to my BIM360 folder.
Then I decided to modify the model for my needs. I downloaded it to my C: drive and changed it as required.
Then I wanted to update the "old" file in the BIM360 system with my new version.
Using Autodesk Desktop Connector I could see the BIM360 file with Windows Explorer. So I just drag-and-dropped my new file over the old one. Unfortunately I did see the file was updated in Windows Explorer and in cloud.
So I decided to upload the file with web interface. With Chrome I have found the folder were the file is located and tried to upload my new file there. I expected that the old and new files have the same name and I will get its new version. Instead of that I've got the error message written above.
To have the file updated in cloud I needed to delete the old file and upload the new one.
My personal expectation is that the system should not prevent me from updating the cloud model because it is not the original architectural file created using Revit Cloud Worksharing, but just a copy of it. And it should not be a difference how I create the copy: with BIM360 command or from my local drive. May be I don't understand the system concepts deeply enough. I would be very appreciated if somebody can explain why does it work in that way and not the way I expect?
Thank you,
Evgeny.
