Help Needed: Bypassing Wizard for File Upload in BIM 360
Dannyisrael
Dannyisrael
Hi everyone,
I’m working on a project in BIM 360, and I’ve encountered an issue when uploading files. After uploading, I receive the message:
“We will process your plans for viewing. Here's what's going to happen next.”
In one of my other projects, I can upload files directly to a directory without going through a wizard or additional processing steps. However, in this specific project, the wizard appears every time, and it seems the file goes into a processing stage for viewing.
I would prefer to upload the file directly to the folder without triggering the wizard. Does anyone know which settings or configurations I need to change in the project or folder to achieve this? Specifically:
  1. Is there a way to disable the "process for viewing" step during uploads?
  2. Could folder permissions or project settings be causing this difference in behavior?
  3. Are there specific upload settings or workflows that might bypass this step?
I’d appreciate any insights or guidance on resolving this. Thank you in advance for your help!
RSomppi
What kind of files and how are you uploading them?
Dannyisrael
I by mistake the upload them to the plan and not to the file that's why I got the wizard
