Change Project Image in New BIM360 (Construction Cloud)
Mircea_Nicolau
Message 1 of 32
Mircea_Nicolau
Hello all,
I don't know if somebody noticed that in new BIM360 that is now called Autodesk Construction Cloud you can't change the image (icon) of a project.
So in the actual BIM360 you will go to Project Admin --> Profile --> and from there you have the option to change the icon/image of a project
So were is that change icon button in ACC? Any Ideas, does exist or it will???
Kind regards,
Mircea
Accepted solutions (3)
Replies (31)
Message 2 of 32
ricardoresende
Also looking for this!
Message 3 of 32
jrice
Happy to see at  least I am not the only one looking for this
Jaret Rice
Autodesk Certified Professional Revit 2015
Message 4 of 32
rliucci
sigh, ditto.
Message 5 of 32
Yien_Chao
you can do it through admin account.
Message 6 of 32
Mircea_Nicolau
If could you be so kind and show us how you change/insert a picture as icon?
I'm telling you, in BIM360 I know how to do it, what I don't know is how to do it in Construction Cloud...
Thank you,
Mircea
Message 7 of 32
DJGinAZ
Same here.
Message 8 of 32
Chad-Smith
Looking for the same.
Message 9 of 32
jpeter
The following is from Autodesk Support, go the Settings page for the project in ACC and copy the project GUID at the end of the URL after projects/
https://acc.autodesk.com/project-admin/settings/projects/{Project_GUID}
Then go to a project profile in BIM360 admin for another project and replace the Project GUID with the one from your ACC project between projects/ and /profile
https://admin.b360.autodesk.com/admin/{Hub_GUID}/projects/{Project_GUID_From_ACC}/profile
I was then able to change the project logo/image.
Message 10 of 32
rliucci
Very Nice JPeter! Thanks!
Message 11 of 32
DJGinAZ
Well done @jpeter. Impressive find!
Message 12 of 32
ricardoresende
Thank you very much!
Message 13 of 32
vitor.martinsBUYSOFT
Hello @Mircea_Nicolau
Go to your Account admin and click at the COMPANIES:
Select your Company of the Project:
Go to Projects and select your Project:
Go to Profile and click Add Project Image:
Message 14 of 32
Mircea_Nicolau
Dear Vitor Martins, many many many thanks!!!
Thank you so much for those picture, they really helped me
thank you
Kind regards,
Mircea
Message 15 of 32
thien.lyson
How can I add an image for Account?
I found it already.
Message 16 of 32
JPeganMDSK
Really...? this is what you have to do in order to add an image.
Message 17 of 32
Mircea_Nicolau
If you will look closer, you will notice that user Vitor provide a perfect answer, much more good then mine.
So, just read the whole post!
PS: You probably did it!
Kind regards
Message 18 of 32
@Mircea_Nicolau
We are here to help and collaborate.
Kind regards.
Message 19 of 32
jan
just the thought that there needs to be a forum post to show people how to add an image to a project profile is bonkers. Autodesk in a nutshell.
Message 20 of 32
Jean-Philippe-Suter
VERY complicated process!
