Can I use BIM 360 Docs to connect A360 and the View and Data API viewer?
jeremytammik
Autodesk Autodesk
jeremytammik
Hi Tristam,
thank you for your clear answer on comparing BIM 360 Docs and A360:
http://forums.autodesk.com/t5/bim-360-docs/bim-360-docs-and-a360/td-p/6056279
I have a follow-up question on that.
Currently, if I upload a file to the View and Data API viewer, I cannot manage it in A360.
Can BIM 360 Docs help me somehow in that respect?
For instance, If I upload a model to A360, can I use BIM 360 Docs to enable me to view it using the View and Data API?
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
mikako_harada
Hi Jeremy,
No, not possible currently.  Consolidating scattered data is something many people are asking.
Incidentally, if a question is related to API, you may choose to post to BIM 360 API forum.  View and Data API is a developer specific topic. It might fit better there.
http://forums.autodesk.com/t5/bim-360-api/bd-p/115
Mikako Harada
