BIM 360 Docs - Can't Add companies or mass import users
jgregoFD7E3
Observer Observer
Message 1 of 21
jgregoFD7E3
Observer
Observer
I am an admin on my project and I am not able to see where I can mass import users and I am unable to see where to add companies.
I followed the following directions and I'm not seeing the options. Please help
http://help.autodesk.com/view/BIM360A/ENU/?guid=GUID-8633D6E0-5986-4111-83FC-EBBE383EE5F6
http://help.autodesk.com/view/BIM360A/ENU/?guid=GUID-ADA50140-D293-43F2-AB9F-0427FDD6FB33
Replies (20)
Message 2 of 21
bogdan_ciobanu
Autodesk Support
Autodesk Support
And thank you for participating in your community.
Both actions you are looking for are available at the account admin level. So to be able to bulk import members or to add companies, you will need to be an account admin, as explained in the articles you mentioned.
To bulk import Members.
You can bulk-import multiple members to an account by using a spreadsheet.
1. In account administration, click Members.
2. Click Add > Import Members By Spreadsheet.
3. Do one of the following:
4. For a first-time import, click Download A Member List Template and open it with Excel. In the template, replace the example entries with your actual member details, one member per row, and save the file. Then click Choose File to select the spreadsheet.
5. If you have a properly formatted member list spreadsheet, click Choose File and select the spreadsheet.
6. Click Start Import.
To add companies.
You can add companies to the company directory or import companies from a Microsoft Excel file. When you add companies to the directory, any project administrator can use the search feature to invite them to their project without creating duplicate entries.
1. In account administration, click Companies.
2. Click Add.
3. In the Create Company dialog, specify the company name.
4. Enter or select a trade from the list.
5. For Company Logo, click Browse to upload an image.
6. Click Save to add the company to the directory.
I hope this was helpful.
If my post answered your questions, thank you for accepting it as a solution so that other community members can see it and use it if they encounter the same issue.
Best regards,
Bogdan
Bogdan Ciobanu
Message 3 of 21
anil_mistry
Autodesk Support
Autodesk Support
Hi @jgregoFD7E3,
I'm just checking in to see if you need more help with this. Did the suggestion that @bogdan_ciobanu provided work for you?
Thank you and have a great day!
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 21
rcopley48676
Hello and thank you for the above solutions. These provide clear instruction on adding bulk users and companies at the account level.
Is there a way to add bulk users at the project level as a project admin? I have found these resources here:
https://knowledge.autodesk.com/support/bim-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/BIM-360-Do...
https://knowledge.autodesk.com/support/bim-360/troubleshooting/caas/sfdcarticles/sfdcarticles/BIM-36...
Following these instructions it seems like it is only possible to add multiple users one at a time, pressing enter after each one. Copy / pasting in a list of comma separated emails doesn't work.
Is there a way to import a spreadsheet or add a list of users at the project level?
Thanks-
R
Message 5 of 21
rcopley48676
Ross
Message 6 of 21
bogdan_ciobanu
Autodesk Support
Autodesk Support
At the moment the modality of adding multiple project members at once is to search for their names in the search bar and then press Enter after each name.
After you have the full list of names, you will need to press Select and then edit their roles.
I am not aware of any possibility to add members from a spreadsheet at the Project level.
Best regards,
Bogdan
Bogdan Ciobanu
Message 7 of 21
It might be possible using Forge:
https://developer.autodesk.com/en/docs/bim360/v1/reference/http/projects-project_id-users-import-POS...
The API allows you to bulk import Members to a hub/account, and import members to a project. Up to 50. If this is a repetitive task might be worth setting up.
Xavier Loayza
www.axoscape.com
Message 8 of 21
anil_mistry
Autodesk Support
Autodesk Support
Hi @jgregoFD7E3,
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 9 of 21
Importing members at the project level or the ability to paste in a list of email addresses separated by comma or semi-colon needs to be implemented quickly.  The amount of work to set up one project with 50+ members is unnecessarily labor-intensive.
Message 10 of 21
david.meyer2QPRZ
This seems to be an issue people have had for almost a year and a half now. Has there been any movement from Autodesk on creating a feature to add multiple users to a project? We just started the process of implementing BIM 360 and without the function of being able to add multiple users (around 20) to a project it almost seems that this will add more time then it will save us in the long run. This seems like a huge miss in its functionality, especially when we are going through around 1,000 smaller projects in one year. Hope they are working on a solution.
Message 11 of 21
BfruehlingWDRZ7
This isn't a solution, but it is a work around. a Member has shown how to use a script to bulk add members. It may be the best option for the next 3-4 years.
https://knowledge.autodesk.com/support/bim-360/learn-explore/caas/screencast/Main/Details/cdd8e180-c...
Message 12 of 21
saifeddine.barkaoui
We are Now in 2021 the problem is not solved, and we receive update of BIM 360 clearly not important like changing the ribbon or the design of the access button. Please Autodesk do something about that problem ! Please help Project Administrators to work easier.
Message 13 of 21
DeepakMaini
@saifeddine.barkaoui @david.meyer2QPRZ @Anonymous I talked about bulk adding members to projects using a spreadsheet in my AU2020 class. If you watch the video in this link below, at 14 mins 13 seconds is where I started from. Have a look at this and let me know if you are interested in that PowerShell script:
https://www.autodesk.com/autodesk-university/class/Connecting-Dots-Between-Office-and-Field-Using-BI...
Cheers
Deepak Maini
ENGINEER | AUTHOR | SPEAKER | MENTOR | PODCASTER
www.deepakmaini.com
Message 14 of 21
saifeddine.barkaoui
Hello Deepak,
Nice work and great video. I appreciate the trick. But What I don't understand is that the function of bulk adding by spreadsheet is available on the Account Admin. But why it cannot possible for a project Admin. In your video you say "How cool is that", you know that this feature is already include in many other BIM cloud platforms, without scripts or other stuffs?
It's not really "cool" to do Autodesk's development work for such a basic function that any Cloud Platform administrator need. They have to fix it ! instead, we get unnecessary cosmetic updates.
Message 15 of 21
DeepakMaini
Totally understand what you are saying mate @saifeddine.barkaoui, but in this class, I wanted to concentrate on the solution that I could make available in the meantime.
Deepak Maini
www.deepakmaini.com
Message 16 of 21
michellem
Hello Deepak;
I watched your video and would really like to get my hands on a copy of this power shell script. Any chance you could send it to me?
Sincerely;
Michelle
Message 17 of 21
DeepakMaini
Hi Michelle, could you please send me an email at [email protected] so I could send you all the information?
Deepak Maini
www.deepakmaini.com
Message 18 of 21
michellem
Hello Deepak;
An email from my office account should be on its way...
Michelle
Message 19 of 21
Philip.Chan.SG
Hello Deepak,
After watching your AU class, I would like to get a hold of the PowerShell script if you are able to share it. I will follow up via email.
Thank you in advance.
Message 20 of 21
ErinChristoffersen
Observer
Observer
We're currently migrating to ACC from a non autodesk program...Has there been any further development on this?
It seems rather crazy that not only can we not batch add multiple companies or members, but then we also need to add members at those companies in order to send any documents for review and approval?? And then these company contacts must accept an invitation to the project and create accounts??
I must be missing something...??
Thanks for your time!
