ACC Build - Can Submittals have custom field or location tag added to them?
MirraLee
MirraLee
Hi
This might be an Ideas post too.
The project we are setting up is horizontal and broken out into bridges and work package names/numbers.
We will be having submittals come in that reference different work packages. I might be missing something, but the submittals do not let you add a custom field or a location tag.
Will custom fields be added or location tags?
Currently, we are using the workaround of spec sections referencing the work package number so that this is a dropdown for the sub-contractor to select.
Does anyone else have this issue or a better workaround? I would appreciate hearing yours.
I appreciate any help you can provide.
Mirra
juanc1479
I second this to be added to the submittals, for each submittal we reference the project's OSHPD number. RFI's have custom fields under the advanced settings.
xionliron
Community Visitor
Community Visitor
I'm the Product Manager for Fields here at ClickUp, and I wanted to thank you for this feedback, and see if you would be interested in jumping on a quick (~20 min) call to discuss in more detail. We are currently scoping some further improvements to the Custom Field Manager, and I'd love to hear more about how we can better meet your needs with the tool. Let me know if you would be interested, and I can send you a link to set up a call https://xender.vip/ !
luisangelgt
I second this Mirra,
Enabling Locations and custom fields within Submittals would significantly increase adoption among large project teams. These capabilities would make the workflow far more flexible, allowing teams to align submittals with their existing project structures and reporting needs.
Recognizing and addressing this gap would greatly enhance the tool’s adaptability and overall value across diverse project environments.
Luis Angel
