I am attempting to create a PDF of https://bim360plan.autodesk.com/list. The application seems to print, but does not pop up a PDF and I cannot find the many PDFs I've attempted to print in the system.
Is there a standard place where PDFs save?
Thank you!
Solved by mike.davison. Go to Solution.
Hi Dawn,
Can you tell us what product you're using here that you're trying to create a PDF with?
BIM 360 Team itself doesn't allow you to create anything, it just allows you to upload different file formats (full list HERE) so that you and others can view them, collaborate on them etc. (markup, comment, share with others, etc)
Let me know and we'll get you pointed in the right direction.
It is a list in BIM 360 Plan. Please see attached.
Thank you for your assistance!
ok thanks Dawn,
I'll move this over into the BIM 360 PLAN forum then for you so that team can help you here. 🙂
Hi - I'm sorry you are having trouble with the printing. Plan prints by opening a new browser tab to display the PDF. Your browser pop-up blocker may be preventing the new tab from opening. Try changing your browser pop-up settings to allow http://bim360plan.autodesk.com to open new windows/tabs to see if that resolves the problem.
Best,
Mike
