Dear,
Please, I'm searching about Building Ops and would like to know if it has compatibility with AutoCAD, Civil3D, Infraworks and Navisworks or if Autodesk has another solution for Facility Management of transportantion projects (subway, highway, railway...)?
Thanks!
Solved by jwinstanley. Go to Solution.
Building Ops is a BIM-enabled, asset and maintenance management solution for Buildings. We support model export to Building Ops from BIM 360 Field and Revit only. Building Ops is not designed to be a solution for managing linear assets, such as highways and railroads.
Thanks for your interest and the question.
Best,
Jason
I think building ops is a maintenance management solution that enables contractors and building owners to realize the value of BIM in building operations.
Is there a roadmap available for the workflow ? How are situation best handled when the authoring software is not Revit?
No, we have no current plans to offer support for additional model-based workflows for uploading data to Ops. We remain committed to providing direct export of equipment data from BIM 360 Field and Revit. For non-model-based workflows, we support the upload of asset data from CSV files, in addition to ad-hoc entry using the mobile and web apps.
Thanks for your question.
Best,
Jason
There are a few suggested paths you might take if you are working with CAD and model data.
There are likely some other variations. Hopefully, this helps.
Best,
Jason
