The "Sheets" toolset in ACC Build should be able to snap to different objects. This ability would significantly improve accuracy when both calibrating and measuring within "Sheets". If the sheet is able to be read by Build's OCR, it should be able to define different objects on the sheet such as gridlines, intersections, scales, etc.
