QA checklist item value and score
We need to assign individual values to each individual QA inspection item.  Then generate section and cumulative scores.  For example:
  • item #1 may have a point value of (1)
  • item #2 (5)
  • item #3 (10)
  • item #4 (2)
  • item #5 (5)
If an item is NA it does not impact the section or cumulative score negatively
Scoring possible points 1+5+10+2+5=23
Example 1:  In the above QA checklist all inspection pass, therefore:
  1. scores 1
  2. scores 5
  3. scores 10
  4. scores 2
  5. scores 5
Total Possible  23, actual score 23 result 100%
Example 2:  In the above QA checklist item #2 fails, therefore:
  1. scores 1
  2. scores 0
  3. scores 10
  4. scores 2
  5. scores 5
Total Possible  23, actual score 18 result 78.2%
Example 3:  In the above QA checklist Item #5 is NA, therefore:
  1. scores 1
  2. scores 5
  3. scores 10
  4. scores 2
  5. scores NA
Total Possible  18, actual score 18 result 100%No penalty if a QA item is scored NA.
We are currently using a database to track or Field QA.  I would like to move it to BIM 360 Build, but I am receiving resistance because there is no scoring associated with it.  Our QA reports are provided to our customers and they like having a quantitative value and not just a pass/fail.  It also makes it easy to see trends.
