You can obviously generate a report and know what models will not be able to be upgraded, can you please provide a link? With all the modules not using single source of truth and needing copies of files, there is no good way to track down which model has the issue as several might have the same name. Yes you could search on the name, but no way to filter out just workshare models. Seems relatively easy for you to just provide a link to the model and or folder where the line item lives. In and of themselves, the report is kind of useless and needs more info put into it. This is super important to save our selves and clients Time, Trouble and Money when there are dozens of projects with tens of thousands of models in them collectively.
Charles Berteaux Iv
BIM360/ACC Guru
Autodesk Expert Elite
Autodesk Certified Professional
Please do not forget to Vote this Idea Up the chain. Every vote counts! Help make this Idea a reality!
