Show only
Search instead for
If you are using Microsoft Teams adding BIM 360 as a Website tab inside a Team Channel at least gives quick access. Use a direct link to the project/folder rather than just adding the Hub. Users get prompted to login (to the Autodesk Account) on first access but after than it seems to stick
Hooray! What is Autodesk planning for this, @joan_allen? Teams integration? Sharepoint document storage syncing? Will this be a native integration or via a 3rd party vendor?
Can you please make your roadmap availeble , it so much happenyning in every release that can affect us it would be very kind to be able to see forward wahts gonna happen
is this working on the US server only at the moment ? I guess this will make its way to the EU server at some point in the future. Be interesting to know when if that could please be confirmed ?
It does not have the functions of the desktop application when you work in the editor, they should enable a function to use it collaboratively from the desktop application such as Revit Work Sharing.
