1) Currently it is not possible to filter Issues in the Model Coordination>Clashes>Assigned tab which limits a lot functionality in this module (see Pic 1).
2) Loading Coordination Spaces after uploading updated models takes too long (very often require switching between coordination spaces if more than one or deactivate and activate again). Although processing automatically is great, would be good having a "Start Check" button to process a new automate clash detection (see Pic 2)
3) Options in Coordination Spaces in Model Coordination are currently very limited. Would be good to be able to chose particular folders/sub-folders or even specific models for each Coordination Space in lieu of having to choose a folder path which reads all the contents (which increments loading/checks time) or force you to configure your folder structure in a way which does not aligned with purposes needed in Document Management or CDE uses. (see Pic 3).
4) There is currently no way to identify or filter which Issues (as result from clashes in Model Coordination) have elements which are no longer clashing between them (after uploading updated models). It has to be checked one by one and the only way to understand is not clashing anymore is visualizing the elements are no longer in green/red graphics. (i.e. Navisworks identifies Resolved clashes in yellow when elements are no longer interfering).
5) BIM 360 have just been recently reading .nwc format files in Model Coordination with no notice in advance. This create several loading issues in coordination space plus increment loading times unnecessarily.
