Maps for Autodesk Desktop Connector
Hi all,
Please add the maps feature to the Autodesk Desktop Connector, because we want to map the Autodesk Desktop Connector to another location and we want to setting all computer to the same address. Example C:\BIM Team\
With this way we can to resolve the problem about the Keynote and CAD link files for model C4R in cloud.
Thanks.
2 Comments
mikel_martin
Can you please add some detail about what issue(s) you are having or believe you will have, which this change would help resolve?
N.Oomen
Hi @Anonymous,
Your solution might be the one that I needed also. Please create your own Registry Entry "Autodesk Drive" and your local path should convert to clouddrive mapping.
Read link below what your registry should be:
Considerations and Known Issues:
This solved the link warning on a different pc, because it will recognize the cloud location as link location.
Hope this helps you out.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
