Make markup tools sticky in AutoDesk Build
When marking up a sheet using any of the shapes/lines,  once you finish the shape you need to reselect the shape between every markup.  It does not stick/have a memory for the shape you just made.   Markups do work this way when using the "Draw" tool only, but Draw is much more difficult to control using a mouse and the lines do not turn out neat.
