Locations Revit Master Model
To define Locations, let's attach a master file with rooms, by analogy as it is done for Design Collaboration for levels and stages.
Why attach files for areas then select these zones inside the file. We already did this in Revit, let's use BIM.
I understand that this is good for PDF and IFC files, but for Revit users let's make the task easier
I found a video how to get rooms from a revit model and then import them into a BIM 360. But can this be done without a workaround?
https://knowledge.autodesk.com/support/bim-360/learn-explore/caas/simplecontent/content/revit-room-i...
