Improvement idea received by Technical Support from our client GRUNER AG, in Switzerland.
Most of the times a sample folder structure (substructure) is used and applied in different folders (for example, the folder structure for each discipline is the same and is created from a sample structure. The same goes for deliverable in different project phases).
If would be a fantastic enhancement if:
- There would be an option to create a folder structure and define it as a template / parent / source.
- This sample structure could be deployed to different target folder at the users' choice.
- The changes in the sample structure can be later deployed in all folder that have been created from it.
Thank you!
Best regards,
Bogdan
