We have encountered an issue in Autodesk Docs concerning "non-workshared cloud models." The thing is, the system doesn't allow us to overwrite these models when we upload them from our local server with the same name. To work around this, we've come up with a workflow where we copy these models to another folder and create versions. This approach helps us share these copied models with clients, who can then add their own "Issues & Markups" and keep them on same models.
The issue is that the system doesn't generate previous "Issues & Markups" on newer versions of the same models. Sometimes we get this message: "Previous markups and calibration are still updating. Check back later" and nothing happens after that. The problem especially arises on Sheets also sometimes on 3D views.
Accessing the "Issues & Markups" from previous versions requires us to select those versions one by one. This means we either have to manage multiple versions on different screens to compare them, or go through a convoluted process of selecting older versions to view "Issues & Markups" and then hit the compare button.
This issue is causing a major headache for us, and we're looking to Autodesk for a solution. Our main request is simple: make "Issues & Markups" visible on all versions of "non-workshared cloud models."
I've attached a screenshot to illustrate the problem. We'd really appreciate your votes for this. Thanks.
Previous Version of a Non-workshared Cloud Model - Sheet View
Newer Version of a Non-workshared Cloud Model - Sheet View
Newer Version of a Non-workshared Cloud Model - 3D View
