I am logging this on behalf of a customer:
The customer and I have noticed that in both BIM 360 Document Management, and in the new Autodesk Docs, that the verbiage used on the messaging/warning for when a user attempts to revert back to a previous version of a document is vague and doesn't state what reverting will do.
Example of current messaging:
Revert Version
We've noticed that when you revert the version, you lose your markups for example. There should be a list of impacted features within the messaging that will warn users not to revert unless it is necessary to restore back to an earlier version if that file had an issue (such as becoming corrupted) and then state what specifically to expect when the reversion occurs.
Thank you,
Scott Green
Senior Technical Support Specialist
