Add the possibilities to add workflows to issues, because in a lot of cases more than one subcontractor or partner is involved in solving the problem.
For example a big crack in a wall after the whole wall is finished: the first subcontractor has to fill the crack using (for example) concrete, once this is done, the second subcontractor has to come to repair the plaster and once this is done, a third subcontractor has to repaint the wall.
Same principal when a socket has to be changed from position. Here is also more than one subcontractor involved.
So I'm looking to have an option, not mandatory to fill in, to activate a one-way, two-way, ... workflow, and once this is selected that you can add subcontractors to each step. All involved subcontractors are receiving a message but only for the first one in the workflow, the status is placed on active, for all the others the status is placed 'on hold'. Of course with an option to have the approval of the main contractor that a previous step is fulfilled correctly before the work of the next subcontractor is activated.
Same principal as the approval workflows for documents:
