BIM 360 Docs - Review for multiple folders
It is now possible to start a review for a folder. But you cannot do this for multiple folders.
First of all, if you select multiple folders in the normal BIM 360 Docs document list, you don’t have a “Review” option, and secondly if you start Review process for one folder, in the next dialog box you can add files from other folders but you cannot add another folder.
1 Comment
chris.conroy
I would like to be able to select multiple documents from different folders (but not the entire contents) for a review.
The obvious way to do this would be using Document Sets as these have been created to link documents together across folders that should be read together, however document Sets cannot be sent for Review.
Chris
