Dear Autodesk,
For locations, it would be great if there was a possibility to drag and drop the levels/area's made to other folders. Now in case, you made one mistake and you need a higher folder. You need to delete all you made, make the highest folder and make all new sub-folders.
And for a second improvement, at this moment you can export the locations. And import them. But you need to delete all the locations before you can import them again.
If you assigned locations this creates issues at the issues (ironical). It would be great if you can export them and they make changes and import. At this moment it gives errors (at least at my tries). So in short, export locations, edit and keep GUID's and then import the file and keeping the guids at same assigned issues/etc.
Best regards,
Josha van Reij
