There is an ageing problem with the fundamental way that B360/ACC Docs stores documents. It uses unintelligent folders that are now becoming a dated method of document storage and management.
Folders have numerous problems:
- They are cumbersome and time-consuming to manage.
- They can be difficult to control granular user permissions.
- They promote file duplication and version confusion across folders.
- Difficult to control files under ISO 19650 conditions.
- In BIM 360 specifically, they can cause issues with file linking.
As a result, Docs needs to move to a metadata-based document management system. One where files are unique, follow conventions like naming, and with linear versioning that doesn't lead to ambiguous duplication.
Under such a system, browsing can be performed with searches/favourites, filtering, or even a 'smart' folders structure that use metadata to only show matching documents. It could even mean that design authoring tools like Revit on Design Collaboration would be smart enough to only show active/filtered live models without the need to unnecessarily traverse folders.
With many other document management systems either moving or have already moved to a metadata storage structure, it is time that ACC/B360 do the same.
