Customize View
Customize View
Currently when we add or remove a new attribute/column to a folder in Plans area, it will affect all the folders, whereas the expected behavior would be to apply it to selected folders/subfolders. Ideally, based on the content and even the stakeholder this attributes/columns would be restructured or at least a view would be customized to view relevant information in the first few columns differently than that of the other folders or subfolders.
Probably between the same lines as the following post:
https://forums.autodesk.com/t5/bim-360-ideas/customize-view/idi-p/6727629
2 Comments
penny_yu
 Hi Asafaryan:
Thank you very much for your suggestion on the custom attributes. This is very helpful!
Penny Yu
BIM 360 Docs
joan_allen
