I have been speaking with Taimur at Autodesk about applying filters to downloads using the cloud drive mapping. He's mentioned that filters only work for the Vault to BIM360 uploads, and not the other way around for downloads.
There are often times when I only need to download certain files from the BIM360 folder, and currently it is downloading everything.
I understand there are some restrictions around available attributes but, filtering based on at least “file extension” and “filename” should be something that is available. These could be easily retrieved and used for conditional download.
Is this something that could be included as part of an upcoming release?
Also, are there any plans to have an option with adding multiple filtering to mapping to make it an “and” or “or” command. Currently it defaults to “and”, but it would be good to be able to choose between.
Becki
